Article ID : 00155133 / Last Modified : 16/01/2026Print
    How to disable the TalkBack function when the screen is dim
    TalkBack is a service that helps visually impaired people, by using audible prompts to guide users to their intended choice/icon. You can turn off the TalkBack function by following these steps:
    1. Press Home button on remote.
    2. Press ↓ (Down arrow) several times, and select Settings.
    3. Press ↓ (Down arrow) twice.
    4. Press → (Right arrow) several times, and select Accessibility.
    5. Press ↓ (Down arrow) once, and select Services.
    6. Press ↓ (Down arrow) once, and select Talkback on.
    7. Select State on, a voice will say on.
    8. Press ↓ (Down arrow) once, then a voice will say off.
    9. Press Enter, then a voice will say OK.
    10. Press Enter.
    NOTE: This issue does not occur when TalkBack is updated to ver 4.1 or later from the Google Play Store.
