Article ID : 00127546 / Last Modified : 15/09/2026Print
    How to set up the set-top box control or IR Blaster to control both the TV and the set-top box
    Before you start
    • This article applies only to specific models, Operating Systems, and countries/regions.
    • If your TV has a TV box setup or Cable/Satellite box setup in Settings — Channels & Inputs or Watching TV — External inputs, the set-top box control is compatible.
    • Google TV™ models and the A8_A8H, XH80_X80H, XH81, XH90_X90H_X91H_XH92, XH95_X95H (55, 65, 75), Z8H_ZH8, Z9H, XH95_X95H (49, 85), XH85_X85H_XH91, A9G_AG9, XG85_X85G_U8G (55, 65, 75, 85), XG95_X95G, Z9G_ZG9 series are all Set-top box control compatible models and can control a set-top box without an IR Blaster.
    • To check the type of your TV, refer to the article How to check if your BRAVIA TV is a Google TV, Android TV™, or other TV.
    • This article applies only to the following countries/regions: Austria, Belgium, Denmark, Finland, France, Germany, Italy, the Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, and the United Kingdom.
