Article ID : 00206652 / Last Modified : 19/01/2026Print
    Screen Reader
    IMPORTANT:
    Blind or partially sighted? Contact Sony using Be My Eyes.
    For more details, check the Applicable Products and Categories section and refer to the Which version of the Android™ OS is installed on my Android TV™? article.
    The Screen reader works by vocalising information on the TV screen, such as the programme guide and setting screen. In order to use the Screen reader function, an internet connection is necessary.
    Notes
    • The Screen reader function only reads text that you can focus or highlight.
    • The Screen reader function is available only for some countries and languages.
    • Whether an app is available with the Screen reader function depends on the app.
    • As of February 2020, the YouTube™ streaming service is available with the Screen reader function. This specification may change without notice.
    • When the Screen reader function is set to ON, some edit options, including Move and Hide in Inputs, might not work.
    • When the Screen reader function is set to ON, some of the Quick Settings edit options might not work.
    • For eARC supported models, when Screen reader is activated, eARC mode will be set to Off.
    • You can adjust the Accessibility shortcut function to enable or disable the Screen reader. Refer to the Accessibility shortcut article for applicable products.
