Article ID : 00157241 / Last Modified : 16/01/2026Print
    Perform a Forced Factory Reset on an Android TV using the TV button(s)
    Performing a forced Factory data reset will remove all customized settings in the TV including downloaded apps, systems data, channels, and wireless network settings. For some models listed below, if you perform a forced Factory data reset, then the Demo data for retail will be erased from internal storage.
    • 2020 models: ZH8 series
    • 2019 models: ZG9, AG9, XG85, XG87 and XG95 series
    • 2018 models: AF9 and ZF9 series
    This article can be used to perform a forced Factory data reset in situations when you can't perform a normal factory data reset, such as:
    • when the software crashes after a firmware update.
    • when the screen of the normal factory data reset doesn't open for some reason.
    Before you start
    • If you can access the TV menu, perform a factory data reset instead.
    • A forced factory data reset can only be done on TVs with Android™ 6.0 Marshmallow or higher operating system installed.
    • This procedure may require two people.
    • The location of the buttons will vary depending on the TV model.
    • Some applications data might be recovered if Apps are synced with your Google™ account. The steps to sync apps vary depending on the TV menu options.
      • HOME → Settings → Device Preferences or Accounts & Sign-In → Google → Choose synced apps → Select items you want to sync with the account → Sync now.
      • HOME → Settings → Google → Choose synced apps in Sync → Select the items you want to sync with the account → Sync now.
      • HOME → Settings → Personal → Google → Choose synced apps in Sync → select the items you want to sync with the account → Sync now.
    How to perform a forced factory data reset
    First, determine the number of buttons on your TV:
    Side by side diagram of two TVs. TV A and TV B
    1. Only one button on the TV: The  (Power) button is located on the bottom center or left side of the TV when viewed from the front.
    2. Three buttons on the TV: The buttons are located on either right or left side of the TV or the back, depending on the model.
    If you can't find the buttons on the TV, refer to the TV .
    Follow the instructions according to the number of buttons on your TV.
