If you update to the latest software and change the language setting, the Google Assistant may become voice search, or the built-in MIC feature may become unavailable.
This is because the Google Assistant and “OK Google” detection features are not supported depending on the language.
From the language setting, select a supported language for each feature.
- The Google Assistant
Supported countries/regions/languages and how to use the Google Assistant - Built-in MIC feature
Supported languages and how to use the built-in MIC (only TVs with a built-in MIC)
NOTE: The display of the language setting will change after updating to the latest software.
The built-in MIC function is available on some models.
