Article ID : 00113329 / Last Modified : 19/01/2023Print
How do I uninstall applications on the Android TV™ or Google TV™?
    IMPORTANT: This article only applies to specific products (Android TVs or Google TVs) and/or operating systems. Please check the Applicable Products and Categories section of this article before starting these steps.
    1. Open the  Settings screen. How to access Settings
    2. Select Apps.
      Notes:
      • If the supplied remote control has an APPS button, you can press the APPS button to display the apps list.
      • The image below is an example of the TV with Android™ 10.0.
    3. The next steps will depend on your TV menu options:
      • Select See all apps — Select an app to be deleted — Uninstall
      • Select an app to be deleted — Uninstall
    Notes:
