Article ID : 00203243 / Last Modified : 21/08/2020Print
    Learn about your Sony Android TV: Android Nougat Interactive TV Guide
    Interactive banner
    Get the most out of your TV through Sony's Interactive TV Guide
    Find out how to set up digital channels, configure Wi-Fi, enable Bluetooth and much more.
    Click through the Interactive TV Guide and discover all functions of your Sony TV!
    How-to steps
    How to Use
    This interactive guide allows you to discover the settings and menu options of your Sony Android TV. By selecting a topic and following the on-screen instructions, you will quickly master your TV settings.
    Start using now!
    TV Functions
    TV functions
    Check out the topics for your TV to get you started:
    [ - ] Getting started
    [ - ] Apps
    [ - ] Picture Settings
    [ - ] Sound Settings
    [ - ] Network Settings
    [ - ] Bluetooth / USB / Voice
    [ - ] System
    [ - ] Support
    Applicable Series:
    • W75C
    • W80C
    • W85C
    • S80C
    • S85C
    • X80C
    • X83C
    • X85C
    • X90C
    • X91C
    • X93C
    • X94C
    • SD85
    • XD85
    • XD93
    • XD94
    • XD70
    • XD75
    • XD80
    • SD80
    • XD83
    • ZD9
    • XE80
    • XE83
    • XE85
    • XE90
    • XE93
    • XE94
    • A1
    • XF75
    • XF80
    • XF83
    • XF85
    • XF87
    • XF90
    • AF8
