Article ID : 00343877 / Last Modified : 18/06/2024Print
    How to turn off TV remote control sounds on your BRAVIA TV
    If you prefer to turn off the sound cues your TV makes when navigating with the remote, then follow these simple steps to disable (or re-enable) the system sounds on your TV.
    How to disable the TV remote control sound cue
    • Press the Home button on your remote.
    • Navigate to Settings. Based on your TV model, the menu path might differ:
      • Select System → Sound → System Sounds → Toggle OFF
      • Select System Sounds → Toggle ON or OFF
      • Select Device Preferences → Sound  → System Sounds → Toggle OFF
    By following these steps, you can easily control the sound cues on your TV and make your viewing experience more enjoyable.
