IMPORTANT: This article applies to Google TV. For Android TV™ models, refer to the Adjusting the Picture setting on my Android TV article. For other BRAVIA TVs, refer to the Adjusting the Picture setting on my LCD TV article.
Picture settings allow for a wide array of changes to colour, contrast, motion settings, and brightness that can improve the way you view content. Picture settings are adjustable when viewing video streams, DVD/Blu-ray Discs, USB drives, and composite/component video content.
NOTES:
- A brief description of each item is displayed on the picture setting screen of your TV. Use this article as a reference to personalise your viewing experience.
- You can alter Picture settings while viewing content.
- When Auto Picture Mode is set to On, the Picture mode will change automatically based on the content. You may notice changes in brightness or saturation when this setting is set to On. You can also turn this setting Off if you prefer to choose your own settings.
To access Picture settings, press the (Quick Settings) button on your TV remote, then select Settings → Display & Sound → Picture and then select a picture setting.
Picture mode
Change the picture quality according to the content you are watching (groups of automatic settings)
Auto Picture Mode
Automatically select the Picture mode based on the content being viewed
Light sensor
Optimize brightness according to ambient light
Brightness
Adjust the backlight to display the brightest whites and deepest blacks
Colour
Adjust the colour saturation level and Hue
Clarity
Adjust the picture clarity and reduce roughness
Motion
Refines moving images and optimizes picture quality based on video content
