Article ID : 00271264 / Last Modified : 10/08/2026Print
    Does my Google TV or monitor have a removable protective film?
    Whether or not your Google TV™ or monitor has a protective film that needs to be removed varies by model; however, most do not have a removable protective film on the screen. The guidance below will show you how to check.
    IMPORTANT:
    • Do not remove any part of the screen surface or its edges unless a removable film has been confirmed; permanent damage will occur.
    • Review the information in this article first. If you're still unsure whether your TV has a protective film, Contact us for help.
    How to identify if there is a removable protective film
    1. Check your TV and packaging for these signs:
      • A flyer with removal instructions (usually attached to the center of the screen)
      • Tape tabs at the upper edges of the screen panel
    2. If you see the tape tabs at the upper edges of the screen panel—even if you cannot find the flyer:
      Your TV likely has a protective film that should be removed before use.
      The flyer may be loose in the box or missing. We recommend checking the packaging thoroughly for the flyer.
    3. If you do not see tape tabs:
      There is no protective film on the screen surface. Do not remove the surface material from the corners or sides of the panel.
    How to remove the protective film (if your TV came with one)
    If your TV includes the flyer and tape tabs at the edges of the screen panel, it has a protective film to help prevent scratches on the screen during shipping and handling.
    Follow these instructions carefully to remove the protective film:
    1. Locate the piece of tape at the upper left and right edges of the TV screen. These serve as tabs for peeling the film off.
    2. Hold both tabs simultaneously and slowly peel off the protective film from top to bottom.
      IMPORTANT: Do not remove the film from side to side.
    Note:
    Even if there are scratches on the screen's protective film, it will not affect the TV screen. The protective film is designed to prevent scratches on the TV screen. Any scratches visible on the protective film are likely to have occurred during manufacturing or transportation. Once the protective film is removed, the TV screen will not have the same scratches.
    Friendly reminders
    • Never attempt to remove the screen's surface unless you are sure a protective film is present.
    • When in doubt, Contact us for assistance—removing the actual screen layer will cause permanent damage.
