Article ID : 00075703 / Last Modified : 16/01/2026Print
Remote codes for Set-Top box or A/V receiver don't work when setting up the IR blaster
    Please try the following if the codes in the IR blaster setup don't work.
    Set-top box
    • Press Home button on the remote control and select Settings > External Input > IR Blaster setup > Set-top box > Input Manufacture name > Model Number Search.
    AV receiver
    • Press Home button on the remote control and select Settings > External Input > IR Blaster setup > AV receiver > Input Manufacture name.
    If you cannot find out your Set-Top box or AV receiver, then it is not supported for use with the IR blaster. In this case, use the remote control supplied with the set-top box or A/V receiver to operate it.
