How to use the Remote Support function on your TV.
The Remote Support function allows the call operator to access the TV remotely and resolve issues directly.
Before you start
- Please contact Sony's call center to speak with an operator.
- Sony needs to access and collect data from your TV in order to provide support services.
- An Internet connection is necessary to use Remote Support. Customers are responsible for maintaining the necessary network environment.
- The Remote Support Session Code is valid for approximately 10 minutes. Please use it within the time allowed.
Activating the Remote Support function
To enable the screen reading function, the Talkback feature is recommended. For details, refer to this article: How to use the Talkback feature.
- On the remote control, press the Mute button 6 times.
Note: If your remote control has a Help button, press it 5 times. - Press the Enter button when Remote Support is read out.
- Please Contact us.
- The next steps will depend on your TV:
- If Remote Support and the BRAVIA CUSTOMER SUPPORT PRIVACY NOTICE are read out, press the Down arrow button.
- If the Online Remote Support Service Terms and Conditions are read out, press the Enter button.
- Press the Enter button after I reviewed & agreed to Terms and Conditions is read out.
- Press the Down arrow button after Please read the following code to support the technician is read out. A Remote Support Session Code consisting of a 9-digit number is read out. Please repeat this code to the operator.
Note: If you miss the Session Code, you can listen to it again using the Up arrow or Down arrow button.
