Article ID : 00160180 / Last Modified : 10/02/2026Print
    What type of analogue extension cable do I need to connect to my Android TV or Google TV?
    Before you start
    • Some TV models released in 2016 come with an analogue extension cable. Check if an analogue extension cable is supplied with your TV.
    • The A/V connector must match the standards (wiring specifications) of the VIDEO IN (AV IN) connection on your BRAVIA TV.
    • Not all analogue adapter cables are compatible with Sony TVs. Even if the cable looks the same as in the pictures in this article, the standards may be different.
    • If you use a different type of cable, the image or sound may not output correctly (e.g. no picture or flickering can occur).
    How to connect the analogue extension cable
    Use an extension cable with connector parts arranged in the following order from tip to base.
    Connector Detail Diagram (A-E)
    • A: 3.5 mm jack size
    • B: Audio Left (L) signal
    • C: Video signal
    • D: Ground
    • E: Audio Right (R) signal
    Here is an example of a proper connection between the TV and source device using an analogue extension cable:
    Connection Diagram (order from left to right: B, C, A)
    • A: VCR, Video game, DVD player, Camcorder, etc.
    • B: Analog Extension cable (supplied with some TV models released in 2016)
    • C: RCA Cable (not supplied)
    Notes:
    • Whether the Analogue Extension cable is supplied depends on your model, region or country.
    • Connect the Analogue Extension cable to the terminal for the VIDEO IN or AV IN on the TV.
    • You can find further information in your TV manual. Manuals are posted on the support website.
