Article ID : 00363785 / Last Modified : 08/08/2025Print
Installing the Zoom app on BRAVIA 3 (S30) / BRAVIA 2 II (S20M2): Which cameras support video calling or chat?
    IMPORTANT:
    • This article only applies to specific products. Please check the Applicable Products section at the top of this article.
    • For other BRAVIA TVs: Information on how to install the Zoom app on other BRAVIA TVs is available here.
    Supported camera models
    The following model is compatible with the BRAVIA 3 (S30) and BRAVIA 2 II (S20M2):
    • Logitech Brio Ultra HD Pro Business Webcam
      (Model number: 960-001105)
    Note: While Sony cannot make any guarantees, the Zoom app may work with other USB cameras (webcams) for Android™.
    How to install the Zoom app on your BRAVIA TV
    Before installing the Zoom app, update your TV to the latest software available (version 6120300300 or higher).
    Follow these steps to install the Zoom app on your BRAVIA 3 or BRAVIA 2 II for video calling or video chat:
    1. Search for Zoom in the Google Play Store.
    2. Install the Zoom app on your TV.
    Notes:
    • If you're unsure how to search for and install an app, refer to this article: How do I install applications on the Google TV™ or Android TV™?.
      • There are many search options available, including the Google Play Store, the Apps tab on the Home screen, the voice search function, and the on-screen keyboard. Available options depend on your TV model.
    • For additional help with installing apps, check out the Help Guide or our Bravia apps article.
    • Depending on your country or region, the Zoom app may not be available. In this case, please contact Zoom for assistance.
