Article ID : 00114539 / Last Modified : 16/11/2026Print
    Troubleshooting unexpected symptoms and issues on a Google TV or Android TV.
    How to know if a downloaded application is causing an issue, and how to resolve the problem)
    IMPORTANT: For BRAVIA 6 (A60) models, refer to the link Troubleshoot unexpected symptoms and issues on a Google TV for these models.
    If an unexpected symptom appears while using your TV, check the following:
    Symptoms
    • Abnormal image, no picture, or no sound for a TV channel or external device
    • No sound or distorted sound, unwanted noise, or interrupted sound when playing video or audio
    • Video, pictures, or thumbnails do not display properly, or display a black screen
    • USB playback, Throw, or Screen Mirroring do not work
    • The app does not operate correctly
    Troubleshooting
    1. Restart the TV.
      Note: For more details, refer to the How to restart (reset) a Google TV™/Android TV™? article.
    2. When the screen becomes black or the image is not displayed correctly in the HDMI/MHL connection, try the following methods to improve it:
      Note: Your TV may not be compatible with an MHL connection. For details on your TV's specifications, refer to the manual.
      • Disconnect and reconnect the HDMI/MHL cable.
      • Disconnect and reconnect the power cord (mains lead) of the connected device, or reboot the device.
    3. If you experience an abnormal image or sound, reset the picture or sound settings:
    4. Software Update is an update program that adds new features and fixes bugs. We recommend that you connect the BRAVIA TV to the Internet, and set the Automatic Software Update option to On.
      Note: For more details, refer to the How to perform a software update article.
    5. If there is no improvement after performing a software update, the issue may have another source. Try searching other FAQs.
      Note: If you downloaded apps other than those that were pre-installed, those apps may be affecting the TV's operation. Check the See if a downloaded app is causing an issue section.
    First, start the TV in Safe Mode and check if the symptoms occur while the downloaded app is disabled. For details on how to operate the TV in Safe Mode, refer to the article How to turn Safe mode On or Off?
    If you were able to start the TV in Safe Mode and confirm that a downloaded app is affecting the TV's operation, try the following troubleshooting steps:
    1. From Google Play Store, update the downloaded app you believe is causing the issue to the latest version available.
    2. Follow these steps to perform the Clear data procedure:
      1. Open the Settings screen.
      2. The next steps will depend on your TV menu options:
        • Select Apps → See all apps → the app with problems. (Android™ 9 or later)
        • Select Apps → the app with problems in the System app or Running app category. (Android 8.0 or earlier)
      3. Select Clear data then OK.
    3. Refer to the app web page, the e-mail address listed, or FULL DESCRIPTION of each app.
      Note: The steps below might be changed without any notice.
    4. Consider uninstalling the app.
