Article ID : 00374547 / Last Modified : 01/12/2025Print
How do I play back DTS:X content on Disney+ with my BRAVIA TV?
    You can play back DTS:X content when the following two conditions are met:
    1. Play DTS:X content only on the following Google TV™ models:
      • 2025 models: BRAVIA 8 II (XR80M2)BRAVIA 5 (XR50)
      • 2024 models: BRAVIA 9 (XR90), BRAVIA 8 (XR80)BRAVIA 7 (XR70)
      • 2023 models: A95L series
    2. Select DTS:X content that has a DTS:X badge, which indicates compatibility with IMAX Enhanced sound (DTS:X).
    Hint:  How can I find Disney+ content with IMAX Enhanced sound?
    (Reference from the Disney+ Help Center: https://help.disneyplus.com/article/disneyplus-imax-enhanced#enable)
    Select the IMAX Enhanced title you want to watch and navigate to the Details tab to see which audio formats are available for the content. A DTS:X badge will be displayed if IMAX’s Enhanced sound is available for the selected title.
    Note: If DTS:X is not displayed in the Details tab even for an IMAX Enhanced title, it's likely your TV model does not support DTS:XDisney+ does not have information about your audio system, so it only delivers DTS:X content to DTS:X-compatible TVs. Therefore, you must use both a DTS:X-compatible audio system and TV to play back DTS:X content on Disney+.
