Article ID : 00122289 / Last Modified : 02/07/2026Print
    What file formats are supported by the Media Player (Album, Music, and Video) apps?
    Some of the picture, music, or video contents on my home network or USB device cannot be played.
    IMPORTANT: This article provides the file formats supported by the application version that was pre-installed on the TV. For the file formats supported by the Media Player application downloaded from the app store, refer to the What file formats are supported by Media Player from the app store? article.
    Please refer to the Supported files and formats in the Help Guide by following these steps.
    1. Refer to your TV's Help Guide.
      • To check the Help Guide on the web or access your Sony Support website product page, refer to the Let us help you find manuals, firmware updates, drivers, and more. article.
      • To check the Help Guide on the TV, if your TV remote control has a Help button, press the Help button, then select Help Guide. If your TV remote control does not have a Help button, follow these steps:
        1. On the remote control, press the (HOME) button and select Apps → Help.
          Note: If Help is not found, follow these steps:
          On the remote control, press the Quick Settings(spanner or gear) button and select Help.
          If Help is not found, select Settings → Help and feedback → Help.
        2. Select Help Guide.
    2. Select Using the TV with Other Devices.
    3. Follow these steps based on your TV’s menu options:
      • Select USB devices → Supported files and formats.
      • Select Supported files and formats.
    4. Select the category you want to check.
    Notes:
    • The Media Player app doesn't support Dolby content.
    • If content cannot be played back even though the file is listed in Supported files and formats, check whether it is corrupt by testing playback on another computer. You may also not be able to play it back on the TV, depending on the file.
    • Although you may be able to play back formats not listed in Supported files and formats, proper operation is not guaranteed.
    • Contents with unsupported codecs cannot be played.
    • About LPCM files (Music):
      • The following TV series do not support LPCM files (Music): W8L, X64L_X70L_X74L_X75L, X77L_X78L, W8K, X74K_X75K, W8, X7, and X74H_X75H.
      • BRAVIA 3 II (XR30M2), BRAVIA 3 (S30), and BRAVIA 2 II (S20M2) models support LPCM files (Music) when using USB.
      • For other models, LPCM files (Music) are only supported on a home network.
    • 4K content cannot be played back on 2K TV models.
