IMPORTANT:
- This article only applies to specific products other than Android TVs. Please check the Applicable Products of this article.
- For Android TVs, refer to: What are the compatible HDR (High Dynamic Range) formats on Sony's Android TV?
- How to tell the difference between an Android and non-Android Smart TV
Check the following.
| Input (Service/Device) | Built-in Tuner | Video Streaming Services/Apps | Input Terminal | ||||
| DVB-S | HDMI | USB | |||||
| HDR format | HLG | HDR10 | Dolby Vision | HLG | HDR10/HLG/Dolby Vision | HDR10/HLG | |
| TV models | XE70 series | ✔*1 | ✔*1 | - | ✔*1 | ✔*1 / ✔*1 / - | ✔*1 / ✔*1 |
| WE75 series WE61 and WE66 Series | - | ✔*1*2 | - | ✔*1*2 | ✔*1*2 / ✔*1*2 / - | - | |
| RE4 series | - | ✔*1*3 | - | ✔*1*3 | ✔*1*3 / ✔*1*3 / - | - | |
| XF70 series | ✔ | ✔ | - | ✔ | ✔ / ✔ / - | ✔ / ✔ | |
| WF66 | - | ✔*2 | - | ✔*2 | ✔*2 / ✔*2 /- | - | |
| RF45 series | - | ✔*3 | - | ✔*3 | ✔*3 / ✔*3 /- | - | |
| XG70 series | ✔ | ✔ | - | ✔ | ✔ / ✔ / - | ✔ / ✔ | |
| WG66 series | - | ✔*2 | - | ✔*2 | ✔*2 / ✔*2 /- | - | |
*1 Please perform the software update.
For how to update, refer to: How to perform a software update
*2 Compatible with all HDR PS4 Game titles via HDMI and HDR videos of built-in Netflix apps and YouTube apps.
*3 Compatible with all HDR PS4 Game titles via HDMI.
Overview of each format
HDR (High Dynamic Range):
HDR enables handling of brightness information of a wide dynamic range compared to SDR (standard dynamic range) signals used in normal broadcasts. This reproduces shades in bright areas that tend to have blown out highlights and tones in dark areas that tend to be lost. It allows for the reproduction of images with depth and three-dimensional effects that make it feel as if you were seeing it with your own eyes.
HLG (Hybrid Log-gamma):
HLG, as the name suggests, is a “hybrid” format that enables the output of HDR images similar to HDR10 and Dolby Vision. It can also express pictures with well-balanced brightness even in TVs in SDR (standard dynamic range).
HDR10:
An HDR technology standard used with Ultra HD Blu-ray.
Dolby Vision:
One of the HDR technology standards developed by Dolby. It brings scenes to life with striking highlights, deeper darks and vibrant colors. Dolby Vision is an HDR solution that creates an immersive, engaging cinematic experience in your home.
*Android TV and YouTube are trademarks of Google LLC.
