Article ID : 00401132 / Last Modified : 27/08/2026Print
    Enable Text scaling on your Google TV
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    Text scaling allows you to adjust the size of on-screen text on your Google TV™. By increasing the text size from 85% to 130%, you can make the program guide, settings screen, and other on-screen text larger. This may improve text readability.
    To turn on the Text scaling:
    1. Select Text scaling.
    2. Select the text size.
