IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
You can configure various TV audio settings such as sound quality and sound mode.
Follow the steps below to access those settings:
- On the remote control, press the Quick Settings (
or
) button.
- Select Settings.
- The next steps will depend on your TV menu options:
- Display & Sound → Picture & Sound → the desired option (e.g., Picture & Sound or Sound).
- Display & Sound → the desired option (e.g., Picture & Sound or Sound).
Note: The actual display may vary, and some settings may not be available depending on your model, country/region, your TV settings, and the connected device.
BRAVIA 9 (XR90), BRAVIA 8 (XR80), BRAVIA 8 II (XR80), BRAVIA 7 (XR70), BRAVIA 5 (XR50), and A95L series
Sound
You can adjust the audio from:
- TV speakers
- an audio system connected via HDMI or optical audio output
- wired headphones or Bluetooth-connected devices.
You can change the following settings:
| Setting | Overview, Setting Values, and Explanation |
| Surround |
Virtually reproduces realistic surround sound.
When set to Auto, this setting automatically switches surround processing according to the values below:
| Surround effect | Adjusts the audio for comfortable surround sound level.
| Voice Zoom | Emphasises voice or ambient audio and is displayed when Post-processing is set to Standard.
| Dialog enhancer | Enhances voices. You can select Dialog enhancer if Post-processing is set to Dolby Audio processing.
| Equaliser | Adjusts the sound based on different frequencies: 125Hz/250Hz/500Hz/1kHz/2kHz/4kHz/8kHz.
| Balance | Adjusts the balance of the left and right audio according to your viewing position.
| Beam tweeter volume | Adjusts the volume of sound reflected from the ceiling. The signal level can also be adjusted from the Beam tweeter setting.
| Advanced auto volume | Keeps the volume level consistent for all input sources. Turn on when you feel a volume level difference between input sources.
| Dolby AC-4 Dialog level | Adjusts the audio emphasis level using the Dolby AC-4 decoder.
| Dynamic range | Compensates for audio level difference between input sources (for Dolby Digital audio and HE AAC audio). Displayed only when Inputs is set to HDMI or during Media Player playback.
| DTS Dynamic range | Adjusts the dynamic range of the DTS signal.
| Post-processing |
Outputs sound processed by Sony acoustic technology.
Ambient Optimisation Pro
Automatically adjust picture and sound according to your environment and viewing position using both the sensors and the microphone on the TV remote control.
Acoustic auto calibration| Setting | Overview, Setting Values, and Explanation |
| Acoustic auto calibration | Optimises the audio output of your TV speakers by measuring the listening environment using the microphone on the TV remote control. Place (or hold the remote) at your listening position. Note: We recommend measuring again if you change your listening position or the position of your TV.
| TV Position | Optimises the TV speaker sound based on the position of your TV. After the TV's position changes, retry the calibration setup when Acoustic auto calibration is enabled.
Advanced settings
| Voice emphasis | Adjusts the audio to make it easier to hear from your viewing position. |
| Sound balance | Adjusts the balance of the left and right audio according to your viewing position. |
Other Google TV models
Sound
Adjust the settings by input such as the TV or HDMI, and other common settings, to enjoy various sound effects. You can configure settings such as those listed below:
Sound modeSelect modes such as Cinema, Music, or Dolby Audio Processing based on your environment and preferences.
| Standard | Optimises the sound quality for general content. Provides suitable sound for any content. |
| Dialog | Suitable for spoken dialogue. Makes it easy to listen to human voices. |
| Cinema | Optimises surround sound suitable for movies. Provides fine sound for movie content. |
| Music | Lets you experience dynamic and clear sound, like that of a concert. Ideal for music and live concerts content. |
| Sports | Simulates the larger space of a stadium or other venue. Perfect for sports content. |
| Dolby Audio Processing | Outputs sound processed by Dolby acoustic technology. |
Adjust the sound quality for each sound mode in models that feature Sound mode.
| Surround |
| Surround effect | Adjusts for comfortable surround sound level.
| Equalizer | Adjusts the sound based on different frequencies:125Hz/250Hz/500Hz/1kHz/2kHz/4kHz/8kHz.
| Voice Zoom | Emphasises voice or ambient audio. Voice Zoom can be selected in Sound Mode except when Dolby Audio Processing is activated.
| Dialog enhancer | Emphasises voice. Dialog enhancer can be selected at Sound Mode when Dolby Audio Processing is activated.
Adjust the sound level of the current input.
| Setting | Overview, Setting Values, and Explanation | |
| Volume offset | Adjusts the sound level of the current input relative to other inputs.
| MPEG Audio Level | Adjusts the MPEG audio sound level.
| Dolby Dynamic Range | Compensates for differences in the audio level between different channels (only for Dolby Digital audio).
| HE-AAC Dynamic Range | Compensates for differences in the audio level between different channels (only for HE-AAC audio).
| HE-AAC audio level | Adjusts the HE-AAC audio sound level.
| Advanced auto volume | Keeps the volume level constant for all input sources. Turn this setting On when you feel a volume level difference between input sources.
| TV position | The TV speaker sound will be optimised based on the position of your TV. After the TV's position changes, retry the calibration setup when Acoustic auto calibration is enabled.
| Acoustic auto calibration | Optimises the audio output of your TV speakers by measuring the listening environment using the microphone on the TV remote. Put (or hold the remote) on your listening position. Note: We recommend measuring again if you change listening or TV position.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
