Article ID : 00288837 / Last Modified : 20/01/2026Print
    BRAVIA TV dimensions of X95K series
    These dimensions are approximate values. For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Standard position
    TV dimensions labeled A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    85X95K, 85X95xK188910861888109756450195
    75X95K, 75X95xK1667961166597256391169
    65X95K, 65X95xK1443835144284660343146
    Using a stand: Narrow position
    Unit: millimetre
    85X95K, 85X95xK18891086758111056450195
    75X95K, 75X95xK166796157198456391169
    65X95K, 65X95xK144383551485960343142
    Using a stand: Sound bar position
    Unit: millimetre
    85X95K, 85X95xK188910861888115856450195
    75X95K, 75X95xK16679611665103356391169
    65X95K, 65X95xK1443835144290760343
    146
    Mounting on a wall
    TV dimensions labeled from A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: wall-mount bracket hole distance (W)D: wall-mount bracket hole distance (H)E: bracket hole distance to side of screenF: bracket hole distance to top of screen
    85X95K, 85X95xK18891086400400745545
    75X95K, 75X95xK1667961300300683479
    65X95K, 65X95xK1443835300300572394
    • G: M6 holes for wall mount bracket
    • For screw length information, refer to the instruction manual.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
