Article ID : 00175124 / Last Modified : 16/01/2026Print
    The Cable holder on the rear of the TV cannot be used when attaching a Wall-Mount Bracket manufactured by other companies.
    This Cable holder is for the Table top stand installation or dedicated Wall-Mount Bracket installation only. For other installations, this Cable holder is not necessary.
    NOTE: Dedicated Wall-Mount Bracket means the one supplied with the TV and SU-WL-8xx sold as optional accessories. Whether the Wall-Mount Bracket is supplied and availability of optional accessories are different depending on the region/country/TV model.
