Article ID : 00280777 / Last Modified : 20/01/2026Print
    Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2022 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING! There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For Safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    • The screw hole distance measurements: Width x Height expressed in mm
      Note: This diagram shows the rear side of a BRAVIA TV.
      Back side of the BRAVIA TV. There is a "C: Screw holes" on the back of the TV, and in this image the horizontal distance between the left and right holes is shown as "A: W (width)" and the vertical distance between the upper and lower holes is shown as "B: H (heigjt)".
      • A: W (width)
      • B: H (height)
      • C: Screw holes
      Notes:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals that come with the TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC Power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility chart.
      Ac Power adapter size. The longest part of the adapter is "A: W (width)". When placed with the "A" side facing toward you, the distance from the top to the bottom of the left and right sides of the adapter is "B: H (height)" and the depth is "C: D (depth)".
      • A: W (width)
      • B: H (height)
      • C: D (depth)
    Sony original Wall-Mount Bracket
    Product NameModel NameReference
    Wall-Mount BracketSU-WL450-
    Wall-Mount BracketSU-WL850-
    Wall-Mount BracketSU-WL900
    • Load capacity: 60kg
    • VESA® hole pitch/Screw hole size (W x H) mm: 300 x 300 / 400 x 400
    Compatibility chart
    2022 TV models
    Model NameSeries NameInchesSU-WL450SU-WL850
    • Weight of TV: within 60kg
    • VESA hole pitch/Screw hole size
      (W x H) mm:
    (W x H) mm
    Length of power cord (mains lead)Weight of TV without Stand
    XR-65A95KA95K Series65✓ *1✓✓300 x 3002 m27.0 kg
    XR-55A95KA95K Series55✓ *1✓✓300 x 3002 m21.2 kg
    XR-48A90KA90K Series48✓ *1✓ *2✓300 x 3001.5 m13.4 kg
    XR-42A90KA90K Series42✓ *1--200 x 2001.5 m13.3 kg
    XR-77A84KA84K Series77✓ *1✓ *2✓300 x 3002 m34.8 kg
    XR-65A84KA84K Series65✓ *1✓ *2✓300 x 3001.5 m23.0 kg
    XR-55A84KA84K Series55✓ *1✓ *2✓300 x 3001.5 m17.9 kg
    XR-77A83KA83K Series77✓ *1✓ *2✓300 x 3002 m34.8 kg
    XR-65A83KA83K Series65✓ *1✓ *2✓300 x 3001.5 m23.0 kg
    XR-55A83KA83K Series55✓ *1✓ *2✓300 x 3001.5 m17.9 kg
    XR-77A80KA80K Series77✓ *1✓ *2✓300 x 3002 m34.8 kg
    XR-65A80KA80K Series65✓ *1✓ *2✓300 x 3001.5 m23.0 kg
    XR-55A80KA80K Series55✓ *1✓ *2✓300 x 3001.5 m17.9 kg
    XR-65A75KA75K Series65✓ *1✓ *2✓300 x 3001.5 m22.9 kg
    XR-55A75KA75K Series55✓ *1✓ *2✓300 x 3001.5 m17.8 kg
    XR-85Z9KZ9K Series85✓ *1-✓400 x 4002 m58.4 kg
    XR-75Z9KZ9K Series75✓ *1-✓300 x 3002 m47.5 kg
    XR-85X95KX95K Series85✓ *1-✓400 x 4002 m53.2 kg
    XR-75X95KX95K Series75✓ *1-✓300 x 3002 m42.7 kg
    XR-65X95KX95K Series65✓ *1✓✓300 x 3001.5 m32.1 kg
    XR-75X94KX94K Series75✓ *1✓✓300 x 3001.5 m34.4 kg
    XR-65X94KX94K Series65✓ *1✓✓300 x 3001.5 m22.9 kg
    XR-55X94KX94K Series55✓ *1✓✓300 x 3001.5 m17.4 kg
    XR-50X94SX94S Series50✓ *1--200 x 2001.5 m13.5 kg
    XR-75X93KX93K Series75✓ *1✓✓300 x 3001.5 m34.4 kg
    XR-65X93KX93K Series65✓ *1✓✓300 x 3001.5 m22.9 kg
    XR-55X93KX93K Series55✓ *1✓✓300 x 3001.5 m17.4 kg
    XR-75X92KX92K Series75✓ *1✓✓300 x 3001.5 m34.4 kg
    XR-65X92KX92K Series65✓ *1✓✓300 x 3001.5 m22.9 kg
    XR-55X92KX92K Series55✓ *1✓✓300 x 3001.5 m17.4 kg
    XR-50X92KX92K Series50✓ *1--200 x 2001.5 m13.5 kg
    XR-85X90KX90K Series85✓ *1-✓400 x 4001.5 m45.8 kg
    XR-75X90KX90K Series75✓ *1✓✓300 x 3001.5 m34.4 kg
    XR-65X90KX90K Series65✓ *1✓✓300 x 3001.5 m22.9 kg
    XR-55X90KX90K Series55✓ *1✓✓300 x 3001.5 m17.4 kg
    XR-55X90SX90S Series55✓ *1✓✓300 x 3001.5 m17.4 kg
    XR-50X90SX90S Series50✓ *1--200 x 2001.5 m13.5 kg
    KD-85X89KX89K Series85✓ *1-✓400 x 4001.5 m44.7 kg
    KD-75X89KX89K Series75✓ *1✓✓300 x 3001.5 m32.6 kg
    KD-65X89KX89K Series65✓ *1✓✓300 x 3001.5 m22.0 kg
    KD-55X89KX89K Series55✓ *1✓✓300 x 3001.5 m17.1 kg
    KD-50X89KX89K Series50✓ *1--200 x 2001.5 m12.7 kg
    KD-43X89KX89K Series43✓ *1--200 x 2001.5 m10.2 kg
    KD-85X85KX85K Series85✓ *1-✓400 x 4001.5 m44.7 kg
    KD-75X85KX85K Series75✓ *1✓✓300 x 3001.5 m32.6 kg
    KD-65X85KX85K Series65✓ *1✓✓300 x 3001.5 m22.0 kg
    KD-55X85KX85K Series55✓ *1✓✓300 x 3001.5 m17.1 kg
    KD-50X85KX85K Series50✓ *1--200 x 2001.5 m12.7 kg
    KD-43X85KX85K Series43✓ *1--200 x 2001.5 m10.2 kg
    KD-85X85TKX85TK Series85✓ *1-✓400 x 4001.5 m44.7 kg
    KD-75X85TKX85TK Series75✓ *1✓✓300 x 3001.5 m32.6 kg
    KD-65X85TKX85TK Series65✓ *1✓✓300 x 3001.5 m22.0 kg
    KD-55X85TKX85TK Series55✓ *1✓✓300 x 3001.5 m17.1 kg
    KD-50X85TKX85TK Series50✓ *1--200 x 2001.5 m12.7 kg
    KD-43X85TKX85TK Series43✓ *1--200 x 2001.5 m10.2 kg
    KD-75X82KX82K Series75✓ *1✓✓300 x 3001.5 m32.2 kg
    KD-65X82KX82K Series65✓ *1✓✓300 x 3001.5 m21.7 kg
    KD-55X82KX82K Series55✓ *1✓✓300 x 3001.5 m15.9 kg
    KD-50X82KX82K Series50✓ *1--200 x 2001.5 m12.4 kg
    KD-43X82KX82K Series43✓ *1--200 x 2001.5 m10.1 kg
    KD-75X81KX81K Series75✓ *1✓✓300 x 3001.5 m32.2 kg
    KD-65X81KX81K Series65✓ *1✓✓300 x 3001.5 m21.7 kg
    KD-55X81KX81K Series55✓ *1✓✓300 x 3001.5 m15.9 kg
    KD-50X81KX81K Series50✓ *1--200 x 2001.5 m12.4 kg
    KD-43X81KX81K Series43✓ *1--200 x 2001.5 m10.1 kg
    KD-65X80KX80K Series65✓ *1✓✓300 x 3001.5 m21.7 kg
    KD-55X80KX80K Series55✓ *1✓✓300 x 3001.5 m15.9 kg
    KD-50X80KX80K Series50✓ *1--200 x 2001.5 m12.4 kg
    KD-43X80KX80K Series43✓ *1--200 x 2001.5 m10.1 kg
    KD-50X73KX73K Series50✓ *1--200 x 2001.5 m12.2 kg
    KD-43X73KX73K Series43✓ *1--200 x 2001.5 m8.9 kg
    KD-50X72KX72K Series50✓ *1--200 x 2001.5 m12.2 kg
    KD-43X72KX72K Series43✓ *1--200 x 2001.5 m8.9 kg
    • *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    • *2 Use of the terminals may be limited depending on usage of the TV.
    About the Strength of Walls
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the wall strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult a Sony dealer or a licensed contractor.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use screws supplied with the Wall-Mount Bracket. The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
    For details about the screws, refer to the Installation instructions (Wall-Mount Bracket) for the TV or Operating Instructions or Reference Guide for the TV.
