Article ID : 00197492 / Last Modified : 16/01/2026Print
    Pairing procedure for iOS devices (iPhone, iPad, Apple Watch, etc.)
    Follow these steps to pair your Bluetooth audio device with an iOS device (iPhone, iPad, Apple Watch, etc.):
    Note: This example is for a device using iOS version 13.x. For details regarding your specific device, refer to the operating instructions supplied with the product.
    1. On the Home Screen, select Settings.
    2. On the Settings menu, select Bluetooth.
    3. Change the Bluetooth function to ON.
      Note: If the Bluetooth function is already set to ON, change it to OFF, then back ON again.
    4. When the list of available devices appears, select the name of the device you want to pair.
    5. When pairing is complete, the word Connected will be displayed to the right of the device name.
      Note: If a passkey (or passcode, PIN code, PIN number, password, etc.) input is required, input 0000.
