Article ID : 00248613 / Last Modified : 10/04/2025Print
Can I connect wireless speakers with different wireless speaker models?
    Can I connect a wireless speaker with different wireless speaker models?
    You can connect a wireless speaker to a different wireless speaker if both support the same wireless function. In other words, you cannot connect wireless speaker models compatible with Wireless Party Chain to wireless speaker models compatible with Party Connect
    Update all the speakers to the latest firmware version. Otherwise, the speakers may not connect even if they all support the Party Connect function.
    For more information on the Wireless Party Chain function, check the online Help Guide, available on the product page of your device.
    Devices compatible with the Wireless Party Chain function
    • SRS-XB20
    • SRS-XB21
    • SRS-XB22
    • SRS-XB30
    • SRS-XB31
    • SRS-XB32
    • SRS-XB40
    • SRS-XB41
    • GTK-XB60
    • GTK-XB72
    • GTK-XB90
    Devices compatible with the Party Connect function
    • SRS-ULT70 (ULT FIELD 7)
    • SRS-ULT1000 (ULT TOWER 10)
    • SRS-XB23
    • SRS-XB33
    • SRS-XB43
    • SRS-XE200
    • SRS-XE300
    • SRS-XG300
    • SRS-XG500
    • SRS-XP500
    • SRS-XP700
    • SRS-XV500
    • SRS-XV800
    • SRS-XV900
    • LSPX-S3
