Article ID : 00352809 / Last Modified : 10/08/2026Print
    Which Bluetooth speakers can I use with the Party Connect function?
    You can enjoy music playback with the Party Connect function by connecting up to 100 compatible Bluetooth speakers.
    Speakers compatible with the Party Connect function
    • SRS-XB23
    • SRS-XB33
    • SRS-XB43
    • SRS-XE200 *
    • SRS-XE300 *
    • SRS-XG300 *
    • SRS-XG500
    • SRS-XP500
    • SRS-XP700
    • SRS-XV500 *
    • SRS-XV800 *
    • SRS-XV900 *
    • ULT FIELD 3 (SRS-ULT30)
    • ULT FIELD 5 (SRS-ULT50)
    • ULT FIELD 7 (SRS-ULT70) *
    • ULT TOWER 10 (SRS-ULT1000) *
    • ULT TOWER 9 (SRS-ULT900)
    • ULT TOWER 9AC (SRS-ULT900AC)
    • LSPX-S3
    * Update to the latest software version to set up the Party Connect function using the speaker buttons.
    Notes:
    • Update all the speakers to the latest firmware version. If not at the latest firmware version, the speakers may not connect even if they all support the Party Connect function. For details about the update procedure, refer to your speaker's Help Guide or Download page.
    • Make sure all of the speakers you want to connect to the Party Connect function are located within 1 m (3.2 ft) of each other.
    • Stop the music playback before setting up the Party Connect function.
