Article ID : 00187472 / Last Modified : 24/10/2023Print
    LF-S50G gesture control overview
    You can control the LF-S50G speaker by using hand gestures that do not require you to touch the unit.
    To initiate your Google Assistant
    Move your hand over the gesture control sensor (the disc located on top of the speaker) from the back side (the NFC tag side) to the front side (the side of the clock display).
    This means that when you're facing the clock, you need to swipe your hand from the back towards you. This is the gesture equivalent of saying "Ok Google", to the speaker.
    LF-S50G Google Assistant inititiation
    To play/pause a song
    Move your hand over the gesture control sensor (the disc located on top of the speaker) from the front side (the clock display) to the back (NFC tag) side. This means that when you're facing the clock, you need to swipe your hand away from you.
    LF-S50G volume down
    NOTE: For this function to work, you must have a music app (i.e. Google Play or Spotify) configured in the Google Home app and have an active wi-fi connection available.
    To play the previous song
    Move your hand over the gesture control sensor (the disc located on top of the speaker) from the right to the left when facing the clock display.
    LF-S50G playing previous song gesture
    To play the next song
    Move your hand over the gesture control sensor (the disc located on top of the speaker) from the left to the right when facing the clock display.
    LF-S50G playing next song gesture
    To control the volume
    • To turn up the volume, put your finger over the gesture control sensor and circle it clockwise within the sensor area. The volume will increase in bursts.
      volume up LF-S50G
    • To turn down the volume, put the finger over the gesture control sensor and circle it counterclockwise within the sensor area. The volume will decrease in bursts
      LF-S50G volume down gesture
