Article ID : 00158841 / Last Modified : 25/05/2022Print
How to delete registered information of all devices paired with the wireless speaker
    Your wireless speaker doesn't support deleting just one set of pairing information. Initialize your speaker to delete all pairing information. Select your speaker model, turn it on (except for CAS-1), and then follow the instructions provided to initialize the speaker.
    Note:
    • WARNING! Initializing the speaker resets the device to factory default settings, which deletes all network settings and pairing information.
    • Depending on the model, it may enter the standby mode after initializing the wireless speaker.
