Applicable Model
This information is for the following model(s):
  • ILCE-7RM6
About This Download
What to Keep in Mind Before Performing the Update
  • You can download the software update using the Creators' App available in the App Store and Google Play.
Benefits and Improvements
  • Adds support for the Preset Focus function with lenses that do not have power zoom
  • Fixes an issue where the monitor may turn on at regular intervals despite being off
  • Fixes an issue where focusing operations may occasionally become unavailable when the movie mode is set to Manual Focus
  • Improves the operational stability of the camera
Notes:
  • If you are using the Camera Remote SDK (Software Development Kit), please check the Camera Remote SDK website for a list of supported devices, download instructions, and FAQs.
    Note: The Camera Remote SDK may be unavailable in some countries or regions.
    Please refer to the Help Guide for details on all updated functions.
File Info
  • Name: BODYDATA.DAT
  • Version: 1.02
  • Size: 338 327 032 bytes
  • Release Date: 21-10-2026
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version of Your Camera
Follow the instructions below to check the system software version:
  1. Select Menu → Setup → Setup Option → Version → Body.
  2. The system software version is displayed.
Notes:
  • If the system software version is Ver. 1.02, the update is not required.
  • If the Date/Time setting screen appears when you turn on your camera, set the date and/or time correctly.
Saving the System Software Data to a Memory Card
IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
To save the system software data to a memory card:
    1. Click the Download button.
    2. After reading the disclaimer, click Download.
    3. Save the file to your computer.
    4. Insert the formatted memory card into the computer.
    5. Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
    Notes:
    • Please use this camera to format the memory card in advance.
    • Before formatting, copy the data to a computer or other device.
      • After formatting, the data on the memory card will be permanently deleted and cannot be restored.
    • Please refer to the camera’s instruction manual for compatible memory cards.
    Power Requirements
    • Power source: Use a fully charged rechargeable battery pack (NP-SA100).
    • The update can only be performed when the battery power level is 51% or higher. We recommend you use a fully charged battery.
    Hardware Requirements
    • Detach the vertical grip from the camera before updating the system software.
    Updating the System Software Version
    Important Notice
    • Use a fully charged rechargeable battery pack (NP-SA100).
    • Do not remove the battery during the update. Doing so may cause the camera to become inoperable.
    • It may not be possible to update if the camera temperature is high. Please wait until the temperature drops before updating.
    Step 1: Update the System Software of Your Camera
    1. Insert the memory card that contains the saved system software data into slot 1 of the camera. Only slot 1 will recognize the system software data.
    2. Select Menu → Setup → Setup Option → Version → Body.
    3. Select Software Update.
    4. Select Execute on the system software update confirmation screen. The software version update will start.
      On-screen message:
      • Update? X.XX → Y.YY
        • X.XX: Current version number
        • Y.YY: Newest version number
      Notes:
      • Do not remove the battery or memory card during the update.
      • After confirming the details, click the Execute button.
      • Scroll down as needed to view the full text.
    5. When the system software update starts, the elapsed time and progress rate will appear. The access lamp will flash 1 time → 3 times → 5 times depending on the progress. The update will take approximately 6 minutes to complete.
      Location of the Access lamp: It's on the bottom right of Rear side.
    6. When the update is complete, the camera will automatically restart. After restarting, press OK on the “Body update complete” screen.
    Step 2: Confirm the System Software Version of Your Camera
    2. The system software version will be displayed.
      The update was successful if the screen shows Ver. 1.02.
    If the Update Fails
    If the system software was not copied correctly to the memory card, the camera may display an error message or signal an error using the access lamp.
    What You May See:
    • The message “The target model for the update file is incorrect” appears on the camera monitor.
    • The access lamp blinks in one of the following patterns:
      • 5 long blinks (0.5-second cycle) followed by 6 short blinks (0.25-second cycle)
      • 7 long blinks (0.5-second cycle) followed by 7 short blinks (0.25-second cycle)
    What This Means:
    • The system software may have been copied incorrectly to the memory card.
    What to Do:
    1. Remove the battery and memory card from the camera.
    2. Prepare another memory card.
    3. Start again from the Saving the System Software Data to a Memory Card section of this article.
