Applicable Model
This information is for the following models:
  • ODS-D280F
  • ODS-D280U
  • ODS-D380F
  • ODS-D380U
  • ODS-D55U
  • ODS-D77F
  • ODS-D77UA
[Contents]
- ODASoftware_5_5_1_mac.zip: Optical Disc Archive Software macOS Version 5.5.1
- ODASoftware_5_5_1_rhel.zip: Optical Disc Archive Software Linux Version 5.5.1
- ODASoftware_5_5_1_win.zip: Optical Disc Archive Software Windows Version 5.5.1
- ODASoftware_ReleaseNote_jp_en_5_5_1_jp_en.zip: Release Notes (EN/JP)
- Filer_Help.zip: Help Guide of Optical Disc Archive Filer Version 5.5.1
- Utility_Help.zip: Help Guide of Optical Disc Archive Utility Version 5.5.1
- ODS-D280 Technical Note x5.pdf: Techinical Note of ODS-D280U/F
- ODS-D380 Technical Note.pdf: Technical Note of ODS-D380U/F
[Overview]
Optical Disc Archive Software is a basic utility that allows users to read/write files from a computer connected to an ODS-D380U/F, ODS-D280U/F, ODS-D77U/F, ODS-D77UA or ODS-D55U Optical Disc Archive Drive Unit.
With this software running on a computer connected to the ODS-D380U/F, ODS-D280U/F, ODS-D77U/F, ODS-D77UA or ODS-D55U, you can carry out the following operations on the ODS-D380U/F, ODS-D280U/F, ODS-D77U/F, ODS-D77UA or ODS-D55U.
<Optical Disc Archive Utility>
- Display device and disc information
- Format discs
- Update the firmware
- Finalize discs (when using a Quad-Layer Write-Once (WO) disc)
- Make option settings
- System Check
<Optical Disc Archive Filer>
- Archive folders and files
- Retrieve folders and files
[System Reqirements]
 Microsoft Windows
 * Microsoft Windows 10
 * Microsoft Windows 11
 * Microsoft Windows Server 2016
 * Microsoft Windows Server 2019
 * Microsoft Windows Server 2022
 macOS
 * macOS Big Sur 11.7.9
 * macOS Monterey 12.6.8
 * macOS Ventura 13.5.2
 Liunx
 * Red hat Enterprise Linux 7.9 64bit
 * Red hat Enterprise Linux 8.6 64bit
 * Red hat Enterprise Linux 8.8 64bit
[Applicable model]
Optical Disc Archive Drive Unit “ODS-D380U/F, ODS-D280U/F, ODS-D77U/F, and ODS-D55U”
[Software version]
After installing this package, the software version will be “V5.5.1”.
[Summary in Ver5.5.1]
<Windows>
- Filer supports to transfer the entire of one ODA cartridge to the PC local storage and the storage device with SMB I/F supported.
- Utility has checked whether the transfer size of the Fibre Channel Host Bus Adapter card is appropriately set when starting up.
<Mac>
- Filer supports to transfer the entire of one ODA cartridge to the PC local storage on Mac
<Linux>
- Support for 64bit Red Hat Enterprise Linux 8.8
<Common item>
- Following firmware updates are also included.
  * ODS-D280U: V2.600 -> V2.610
  * ODS-D380U: V1.210 -> V1.220
Refer to the release notes for details (especially precautions and instructions).
Release Note (zipped both English and Japanese) is available in the download items above.
