Applicable Model
This information is for the following models:
- ILCE-7RM4A
About this download
Benefits and Improvements
- Improves the overall stability and performance of the camera
File Info
File Name
- Update_ILCE7RM4AV110.exe
File Version
- 1.10
File Size
- 343 MB (360 709 152 bytes)
Release Date
- 07-12-2021
Preparation
Check the system software version
Follow the instructions below to check the system software version. If the system software version is Ver. 1.00, the update is required.
Note: If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and time to the correct values.
- On the camera, select Menu → Setup6 → Version.
- The system software version is displayed.
System Requirements
Operating Systems
The latest version of the system software update is compatible with the following versions of Microsoft Windows:
- Windows 11
- Windows 10
- Windows 8.1
Computer Hardware
This system software update requires the following hardware:
- Intel-based PCs or AMD-based PCs (ARM-based PCs are not supported)
- Hard drive space: 600 MB or more
- RAM: 600 MB or more
Other Hardware
- Power source for the camera: Use a fully charged rechargeable battery pack NP-FZ100. Note: The update can only be performed when the battery power level is
(three bars) or more. We recommend that you use a fully charged battery. Detach the vertical grip before updating system software.
- Use the USB cable supplied with the camera. Note: Update functionality is not guaranteed with any other USB cable.
Download & Install
Important Notice
- Close all other application software before updating the system software.
- Use a fully charged rechargeable battery pack (NP-FZ100).
- Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
- Remove the memory card from the camera before starting the update process.
- The system software update will take approximately 10 minutes. Do not allow your computer to go into Sleep mode during this time. Note: If the computer does go into Sleep mode and the update is interrupted, the entire update process will need to be restarted.
- Do not open About This System Software Updater in the System Software Updater menu as this may cause the software to crash.
- Do not connect the camera to any other devices except your computer.
- Do not connect the camera and computer until instructed to do so.
- Ensure that your computer is connected to the Internet.
- Following the instructions in the System Software Updater window, on the camera, select Menu → Setup4 → USB Connection, and then check if Mass Storage has been selected. If a mode other than Mass Storage is selected, select Mass Storage.
How to download the Updater:
- Click the Download button above.
- After reading the disclaimer, click Download.
- The Update_ILCE7RM4AV110.exe file will start downloading. Note: File Size: 343 MB (360 709 152 bytes)
- Save the file to the desktop of your computer (recommended). Note: With the standard settings of Microsoft Edge, the update file will be saved in your Downloads folder. Click the Desktop tile from the Start screen and find the downloaded file in the Downloads folder by using Explorer.
Step 1: Start the Updater
- Close all programs currently running on your computer.
- Double-click the Update_ILCE7RM4AV110.exe file that you downloaded. Do not connect the camera to the computer yet.
- The System Software Updater starts.
- Turn on the camera and connect it to the computer with the supplied USB cable. USB Mode will appear on the LCD screen of the camera.
- Click Next. The current and updated version numbers appear on the lower left side of the screen. IMPORTANT: Never turn off the camera or disconnect the USB cable while updating.Note: If the computer cannot find the device, the message Could not find the camera for this update is displayed on the computer screen. Please try the following:
- Disconnect the USB cable and connect it again.
- If the computer has multiple USB terminals, try with the other terminals.
- After confirming that the current software version is Ver. 1.00, click Next. If the current system software version is Ver. 1.10, the update is not required. In this case, disconnect the camera from the computer and click Finish, turn off the camera, remove the battery pack, reinsert the battery and turn the camera back on.
- Update is required
- Update is not required
- The camera will reset automatically.
- Start the update. After automatically resetting, the update will begin and a progress bar will appear. The update will take approximately 10 minutes to complete.
- When the update is complete, the camera will automatically restart. When the LCD screen appears again, click Finish, and then disconnect the USB cable.
Note: After restarting, a data recovery warning may display. This is normal. Please wait until this warning disappears.
Step 2: Confirm the system software version of your device
Questions & Answers
The update does not complete
If the monitor remains black for more than 10 minutes, follow these steps to troubleshoot the issue:
- Disconnect the USB cable from the computer.
- Remove the battery and AC adaptor from the camera, leave it for a few minutes, then insert the battery again or connect the AC adaptor.
- Restart the computer.
- Turn on the camera and perform the installation process again.
