Applicable Model
This information is for the following models:
- ILME-FX6T
- ILME-FX6TK
- ILME-FX6V
Required Downloads
Read this section before downloading the file.
To install this update, you need to download the Sony Camera Driver first. For details, read the How to download the Sony Camera Driver section in this article.
About this download
Benefits and Improvements
- Add the AI-based Real-time Tracking AF, and if the Touch Function is set to Tracking AF, you can use Real-time Tracking to track the subject even during manual focus
- Add the Breathing Compensation for consistent angle of view when focusing
- Add the 16-bit RAW output via HDMI
- Add the bokeh adjustment mode for easy adjustment while minimizing exposure changes
- Add new features that support High Dynamic Range (HDR) and Standard Dynamic Range (SDR) dual production for SR Live
- SDR Emulated Preview Display on EVF
- SDR Gain Metadata Recording
- Add the Picture Cache Recording function, which is also supported when shooting with S&Q Motion
- Displayed the 4-channel audio level meter on the on-screen display
- Add the other useful features
Previous Benefits and Improvements
- Adds the 100P and 120P options to the Slow & Quick Motion frame rate menu when the codec is set to RAW or RAW & XAVC-I
- Fixes an issue where the EI value is not reflected correctly during playback in Cine EI mode
- Improves the overall stability of the camera
File Info
File Name
- Update_ILMEFX6V200.dmg
File Version
- 2.00
File Size
- 559.8 MB (559 725 050 bytes)
Release Date
- 27-01-2022
Preparation
Check the system software version
Follow the instructions below to check the system software version. If the system software version is V.1.10 or earlier, the update is required.
- On the camera, select Menu → Maintenance → Version.
- The system software version is displayed.
System Requirements
Operating Systems
The latest version of the system software update is compatible with the following Macintosh versions:
- macOS 10.14, 10.15, 11, 12
Computer Hardware
The latest version of the system software update is compatible with the following hardware:
- Hard drive space: 600 MB or more
- RAM: 600 MB or more
Other Hardware
- Power source for the camera: AC adaptor
- USB cable supplied with the camera Note: Update functionality is not guaranteed with any other USB cable.
Download & Install
Important Notice
- Close all other application software before updating the system software.
- Always connect a supplied AC adaptor when upgrading. If a battery pack is attached at the same time, the upgrade will continue if the AC adaptor is subsequently disconnected.
- Remove the memory card from the camera before starting the update process.
- The system software update will take approximately 25 minutes. Please do not allow your computer to go into Sleep mode during this time. Note: If the computer does go into Sleep mode and the update is interrupted, the entire update process will need to be restarted.
- Do not open About This System Software Updater in the System Software Updater menu as this may cause the software to crash.
- Do not connect the camera to any other devices except your computer.
- Do not connect the camera and computer until instructed to do so.
- Make sure your computer is connected to the Internet.
- On Mac computers with an Apple silicon (Apple M1) processor, please change the security policy. The About This Mac screen will show an item labeled Chip, followed by the name of the chip. Refer to the How to change the security policy on Mac computers with Apple silicon article. For Mac computers with an Intel processor, this step is not necessary.
How to download the Sony Camera Driver:
- Visit the Sony Camera Driver download page and download the appropriate driver: Note: The Sony Camera Drivers are different for Mac computers with an Intel processor and those with an Apple silicon processor.
- Click the Download button.
- After reading the disclaimer, click Download.
- Save the file to the desktop of your computer (recommended).
How to download the Updater:
- Click the Download button above.
- After reading the disclaimer, click Download. Note: The Update_ILMEFX6V200.dmg file will start downloading.
- Save the file to the desktop of your computer (recommended). Note: File Size:559.8 MB (559 725 050 bytes)
Step 1: How to Install the Sony Camera Driver
- Close all programs currently running on your computer.
- Double-click the Camera_Driver_2102a.dmg or Camera_Driver_2110a.dmg file you downloaded. Do not connect the camera at this point. Note: If you have connected the camera to a computer, disconnect it before following the procedure.
- The Sony Camera Driver Installer is expanded.
- Double-click the SonyCameraDriver.pkg icon.
- The installer screen opens. Proceed as instructed.
- You are asked to allow the system to start installation. Type the password for the administrative account.
Notes:- If the operating system displays the System Extension Blocked dialog message (the actual message will vary depending on the operating system version), click the Open Security Preferences button. The macOS Security & Privacy screen opens.
- If the operating system does not display the System Extension Blocked dialog message, go to Step 2: Start the Updater onward.
- In the Security & Privacy screen, open the General tab and then click the key icon. When prompted to enter the password, type the password you used when logging in with the administrator account and then click the Unlock button.
- Click the Allow button to allow the system to start loading the system software.
- After clicking the Allow button, if you are asked to restart, restart the computer and return to the beginning of the update procedure.
- If the Security and Privacy screens does not disappear, please close the window.
- Double-click the Update_ILMEFX6V200.dmg file you downloaded. Do not connect the camera at this point.
- Update_ILMEFX6V200 is expanded.
- Double-click the SystemSoftwareUpdater icon.
- The message prompts you to allow the application to make changes. Type the password for the administrative account.
- The System Software Updater will start.
Notes:- If the system is not ready to start updating, an error message appears. Take appropriate action according to the message and then double-click SystemSoftwareUpdater again.
- If the message You need to restart your computer. appears, restart the computer and then double-click SystemSoftwareUpdater again.
- If the message You need to install Sony Camera Driver appears, perform the procedure described in Step 1: How to Install the Sony Camera Driver, then double-click SystemSoftwareUpdater again.
- If the message Check the Security & Privacy setting. appears, perform steps 7 and 8 in the Step 1: How to Install the Sony Camera Driver section, then restart the computer and double-click SystemSoftwareUpdater again.
- Turn on the camera and connect the camera to the computer with the supplied USB cable, USB Mode appears on the LCD screen of the camera.
- Click Next. The current version number and updated version number appear on the lower left side of the screen. IMPORTANT: Never turn off the camera or disconnect the USB cable while updating.Note: If the computer cannot find the device, the message Could not find the camera for this update is displayed on the computer screen. Please try the following:
- Disconnect the USB cable and connect it again.
- If the computer has multiple USB terminals, try with the other terminals.
- After confirming that the current software version is Ver. 1.10 or earlier, click Next. If the current system software version is Ver. 2.00, the update is not required. In this case, disconnect the camera from the computer and click Finish, turn off the camera, remove the battery pack, reinsert the battery and turn the camera back on.
- Update is required
- Update is not required
- The camera will automatically be reset.
Note: The Loading icon may not be displayed depending on the OS version that you are using. - After automatically resetting, the update will begin and a progress bar will appear. The update will take approximately 25 minutes to complete. IMPORTANT: Never turn off the camera or disconnect the USB cable while updating.
- When the update is complete, the camera will automatically restart.
- When the LCD screen appears again, click Finish and disconnect the USB cable.
Note: After restarting, a data recovery warning is sometimes displayed. This is normal. Please wait until this warning disappears.
Step 3: Confirm the system software version of your device
Note: For Mac computers using an Apple silicone processor, once the update procedure is finished, we recommend setting the security policy back to the original setting. On Mac computers with an Intel processor, this step is not needed. Refer to the How to change the security policy on Mac computers with Apple silicon article if necessary.
Questions & Answers
The update does not complete
If the monitor remains black for more than 25 minutes, follow these steps to troubleshoot the issue:
- Disconnect the USB cable from the computer.
- Remove the battery and AC adaptor from the camera, leave it for a few minutes, then insert the battery again or connect the AC adaptor.
- Restart the computer.
- Turn on the camera and perform the installation process again.
After launching the system software updater, the screen for confirming the version does not appear and a Failed to update message is displayed.
If this happens, it is possible that you have updated your camera in the past using the System Software Update Helper driver and have not uninstalled that software:
- Download System Software Update Helper again and uninstall the driver using the uninstaller tool in the Uninstaller folder of the downloaded file.
- After uninstalling the System Software Update Helper driver, double-click the Update_ILMEFX6V200.dmg to restart the update.
ILME-FX6 System Software (Firmware) Update Ver. 2.00 (Mac)
