Applicable Model
This information is for the following model(s):
- NEX-FS700
- NEX-FS700E
- NEX-FS700EK
- NEX-FS700R
- NEX-FS700RH
The system software update for optimizing the new lenses performance.
(Applied to the lenses releasing after 2016 March)
NOTE
This software is for upgrading from V3.00 or higher only. This software can only be used to upgrade NEX-FS700R or NEX-FS700RH (or an NEX-FS700E or NEX-FS700EK which has been modified by a Sony engineer and upgraded to V3.xx). If you have an NEX-FS700E or NEX-FS700EK that has not been modified, you will need to install V2.20
