Article ID : 00084137 / Last Modified : 14/04/2022Print
    Wi-Fi Direct/Screen mirroring supported device cannot connect to BRAVIA, how to confirm the permission of the device?
    Please check the following.
    • Wireless devices, such as a router, cordless phone, wireless TV receiver, radio, wireless camera, Bluetooth device, or microwave, emit strong radio waves that may disrupt Wi-Fi Direct performance.
      We recommend these wireless devices be placed far from the TV and mobile phone while performing Wi-Fi Direct.
    • Since the frequency of 2.4GHz has a lot of interference and noisy environment, packet collision will sometimes occur. Even though we have implemented noise-reducing countermeasure to improve the image quality, our TV software could not guarantee that there is no packet loss during transmissions.
    • Please try to turn the TV to Off then to On with the remote control to recover.
    • Please confirm the permission status on Show Device List / Delete.
      If permission is Decline, please delete the registered device from the list and then register it again.
      How to delete the registered device
      For Android TV models:
      1. Press the HOME button on the remote.
      2. Select Settings.
      3. Select Network.
      4. Select Wi-Fi Direct.
      5. Select Advanced settings.
      6. Select Show Device List/Delete.
      7. Select Delete all.
    For Other TV models:
    NOTE: The steps below use as an example.
    For details on operation method, refer to the manual supplied with the product.
    2. Select Settings.
    3. Select System Settings.
    4. Select Set-up.
    5. Select Network.
    6. Select Wi-Fi Direct Settings then press the OPTIONS button on the remote.
    7. Enter Show Device List/Delete then press OPTIONS and select All Delete.
    • If there is new TV software available, please download the new software and update the TV.
      For how to update, refer to:  How to perform a software update.
      NOTE: For models other than Android TV released in 2017, refer to the following procedure for performing a software update.
      1. Press the Home button on the remote control.
      2. Select Settings.
      3. Select Customer Support.
      4. Select Software Update.
      5. Select Network.
    NOTE: Please try another mobile device or restart the device if the connection is lost or feel unsatisfied with the connection.
