IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
Check the Before you start section, then select the appropriate issue depending on the situation.
Content
- Before you start
- Issue 1: When the image is out of focus from the beginning
- Issue 2: When the image was in focus at first but has become out of focus after using the projector
Before you start
Regardless of the situation, first check the following:
Check for a tilt or curve in the screen
If the front of the projector is not parallel to the screen, the image might be out of focus.
It also may cause the center and four corners of the screen to be out of focus at the same time. For details, check the following:
1. Adjust the installation angle of the projector
2. Adjusting the image position with the projector
3. Adjusting the focus on the projector
Check the installation environment, and make sure the issue is resolved using your preferred images.
1. Prepare the installation environment for the projector
2. Adjusting the projector focus.
If the issue is not resolved, service may be required.
