Applicable Model
This information is for the following model(s):
- PVM-X3200
Updates of this version
- Function Improvements
The following new feature and improvement are available.- The factory default settings for Ch.28 to Ch.30 have been changed for HLG Extended Range and so on.
- Improved so that markers/Grid Display can be displayed outside the active video area.
- Bug Fix
The following bug has been fixed.- On the PVM-X1800, enabling the interlace display function may cause image flicker.
For further details, please refer to the Release Notes for "Release Notes for_PVM-X3200_X2400_X1800_V5_02.pdf".
Note: The monitor keeps user data stored after the update. If you want the new F Key Preset to appear or apply the setting changes for Ch.28 to Ch.30 in Feature Change ID 1 of V5.02, you will need to perform “User Reset”. The monitor returns to the factory data with the exception of the password, the settings saved using All User Data and the stored User LUT1 to User LUT30 data. This means user data that was not saved is cleared when you perform “User Reset” in the “Administrator” menu.
Updates of V5.01
The following new features and improvements are available.
- Background processing EMO output function for HDR-SDR and 3D LUT conversion
- Side by Side left/right swap function during HDR-SDR conversion
- Free settings for EMO video when side by side
- HDR-SDR conversion during Quad View Display mode (HD only)
- Free settings for EMO (conversion output) video in Quad View (HD only)
- Single Link 4K/HD auto-sensing (adapted to SDI Input 1 or SDI Input 3)
- Interlaced display function
- Black Detail Mode for HDR
- Source ID display function
The following issues from Ver.5.00 have been improved.
- The displayed image is disturbed when an unstable signal is input to other terminal which is not selected.
- The luminance of the internal signal is low, when BlackDetailMode400,500,600,700 is selected.
Applicable version
- PVM-X3200 Ver.2.00 or later
Note: The software version for the monitor can be found on the Unit Status of the Status menu.
Preparation
You will need 1 USB memory stick for the installation.
Specification: USB 3.0 up to 8GB, FAT32 format
For more details, please read “Handling a USB memory stick” in the operating instructions of the PVM-X3200, PVM-X2400 and the PVM-X1800.
Note:
You need to upgrade both the software and the FPGA.
In the case of Ver.2.00, this update procedure takes about 1 hour and 25 minutes per PVM-X3200/X2400/X1800 unit.
In the case of Ver.3.01 or later, this update procedure takes about 1 hour and 7 minutes per PVM-X3200/X2400/X1800 unit.
How to update
Please refer to "Release Notes for_PVM-X3200_X2400_X1800_V5_02.pdf”.
