Article ID : 00252128 / Last Modified : 30/08/2021Print
    How can I calculate the throw distance on a projector?
    Calculating the projector’s throw distance is fairly easy and can be worked out through the below equation:
    Width of screen x Lens throw ratio = Throw distance
    The throw ratio can be found in the Specifications section of the projector’s product page.
    For example:
    The VPL-FHZ75 has a throw ratio of 1.39:1 to 2.23:1.
    If your desired screen width is 100” (2.54m),
    100” (2.54m) x 1.39 to 2.23 = Throw distance of 139” to 223” (3.53m - 5.66m)
    This means that the VPL-PHZ75 can be mounted at any distance between 139” and 223” (3.53m to 5.66m) to make a 100” (2.54m) screen size.
    To make things easy, you can also download our Projection Simulator.
