Article ID : 00253272 / Last Modified : 10/01/2025Print
    What can I display on the VF (viewfinder) while shooting with S-Log3?
    If you display S-Log3 shooting directly, you can check the dynamic range of the faint and soft image.
    You can convert this into a gamma equivalent of Rec.709 and display, if you turn the Gamma Display Assist function on.
