Applicable Model
This information is for the following model(s):
- K-48A62 / BRAVIA 6
- K-48A65 / BRAVIA 6
- K-48A69 / BRAVIA 6
- K-55A62 / BRAVIA 6
- K-55A65 / BRAVIA 6
- K-55A69 / BRAVIA 6
- K-65A62 / BRAVIA 6
- K-65A65 / BRAVIA 6
- K-65A69 / BRAVIA 6
- K-77A62 / BRAVIA 6
- K-77A65 / BRAVIA 6
- K-77A69 / BRAVIA 6
This update is compatible with all firmware versions of all applicable model(s).
About this download
Benefits and improvements
- Improves general stability of the TV
What to keep in mind
- Only for use with TVs sold in Europe. Not all models are sold in all countries/regions.
- Before downloading the update, make sure your model is in the list of Applicable Products mentioned at the top of this page.
- Do not attempt to install this software on a TV model that is not listed on this page. Doing so could create issues with your TV's functionality.
Preparation
Check the software version
Your software may already be up to date. If you're not sure, it's easy to check which software version you have by following these instructions:
- On the TV remote control, press the Home button, and then press the
(Dashboard) button to open dashboard.
- Select All settings.
- Select System.
- Select About.
The software version number, UKNx.xxxxxx.xxx, is shown as Android TV OS build.
If the version number is UKN7.260716.030 or higher, you already have the most recent software version, and updating is not required.
How to update the firmware on your BRAVIA TV
Choose one of the following procedures:
- Using the Automatically check for update function (easy)
Note: Your TV may indicate the Software is up to date even if the newer version is not installed. The updates for automatic software downloads are staggered releases and may not be immediately available. Please try again later. If you prefer to update now, follow the instructions to download and install the software update using the USB flash drive method. - Using a USB flash drive
Using the Automatically check for update function (easy):
You will automatically receive a notification to update your TV. However, you can also check for an update manually by following the steps below.
- Select System.
- Select About.
- Select System update.
The new firmware update will be rolled out gradually to all Internet-connected TVs over the weeks following its release.
IMPORTANT: The following System requirements, File info, and the Download and install sections all relate to the USB flash drive update procedure. You can ignore them if you completed the update using the Automatically check for update feature.
For other FAQs and troubleshooting, please see the Questions and answers on the Sony Support Site.
Using a USB flash drive:
You can also update the software by using a USB flash drive. If an Internet connection is not set up on your TV, or you don’t want to wait for the update via the Automatically check for update function, try to download and update using a USB flash drive as instructed below.
System requirements
What you need
- a computer with access to the Internet
- a USB flash drive
Note: You can update your TV even if there are other files in the USB flash drive.
File info
File name
- Firmware update to v7.260716.030 for TV
Zip file name
- sony_tvupdate_2026_7260716030_www_auth.zip
File version
- 7.260716.030
File size
- 1 814 657 521 bytes
Release date
- 04-11-2026
Important notice
- This update is necessary to maintain the conformity of the product.
- Read the instructions carefully or you could end up causing the TV to become unresponsive or require a repair.
- Do not turn off the TV or disconnect it from power while it's updating.
- Do not press any buttons, except the ones mentioned in the instructions.
- Stop any recording before you start the firmware update (USB HDD recording models only).
How to download the updater
Before you install the update, you'll need to download it from the Internet and save it to a USB flash drive.
- Click the Download button at the top of this page, then read and accept the terms and conditions.
- Once you have accepted the terms and conditions, click the Download button at the bottom of the page to download the update file to your computer.
- Verify the downloaded file name and size (see the File Info section).
- Extract the downloaded file to a location on your computer that you can easily find.
- Ensure the newly created sony_tvupdate_yyyy_yyyyyyyyyy_www_auth folder contains the following file:
- upgrade_image_no_tvcertificate_project_id_persist_config.pkg
- Insert the USB flash drive into your computer.
- Go to the location where the extracted file is saved and copy (or drag and drop) upgrade_image_no_tvcertificate_project_id_persist_config.pkg into the root directory of the USB flash drive.
Note: The root directory is the first or top-most directory of the device, which contains all the other folders. - Remove the USB flash drive from your computer and continue to the next section.
Step 1: Install the update
Once you've downloaded the update file and prepared your USB device, you can install it on your TV. The process can take up to 30 minutes, and during the installation, your TV will turn off before turning itself back on.
Follow these steps to install the update:
- Turn off your TV and unplug the power cord from your TV.
- Remove any USB devices connected to the TV.
- Insert the USB flash drive containing upgrade_image_no_tvcertificate_project_id_persist_config.pkg into a Blue USB 3.0 port on the TV.
- Reconnect the TV's power cord.
- The update starts automatically when the TV detects the USB flash drive. An update progress screen appears.
- Wait approximately 10 minutes. The TV will turn off and back on automatically to complete the update.
WARNING! During the software installation process, please:- Do not remove the USB device
- Do not disconnect the TV from the power supply
- The TV will restart automatically once the update is completed.
- Carefully remove the USB device from the USB slot.
Step 2: Check that the update was successful
Check the current software version to confirm that the update was successfully installed.
- If the version number is UKN7.260716.030, the software update was successful.
- If the version number isn't UKN7.260716.030, download and install the update again.
FAQs
- Will my personal settings be deleted after the update?
No, all your personal settings will be kept. - Can I install an older version of the software?
No. To ensure that your TV remains at optimum performance, the installation of an older software version is not possible. The latest software version contains all the benefits and improvements of previous versions. - Is it normal for the TV to turn off during the update process?
Yes, it's normal for the TV to restart during the update process. It will take longer for the TV to restart while installing the new software. - When should I insert the USB flash drive?
First, complete your TV’s Initial setup before trying the update. Then turn off the TV, disconnect the power cord, and insert the USB flash drive.
What to do if you have problems updating your TV firmware
If either message An error occurred during the software update is displayed on the TV screen, please proceed to the following procedures for a possible solution:
- Repeat the installation process.
If the message No newer version of the TV software was found is displayed on the TV screen, your TV already has the newest software version installed, so you don't need to update it.
Note: If you are trying to update the software using a USB flash drive, check the following.
- Make sure your USB flash drive is in good working order.
- The drive must be larger than 8GB and formatted in FAT32.
- The update can fail even when using a USB flash drive that meets the above conditions, depending on the size and directory structure of other files on the drive. If the update does fail, delete other files and try again with only the update file saved in the USB flash drive.
For other FAQs about troubleshooting, please see the Questions and Answers section on the Sony Support Site.
