Article ID : 00303365 / Last Modified : 18/10/2024Print
    Xperia 10 IV software release overview
    Welcome to the Xperia 10 IV software release page.
    • Each Xperia smartphone receives security and software updates throughout its lifecycle.
    • Software release timings may vary by operator, market, region, or country.
    Latest software release
     Date
     Android version
     Software version
      Software improvement
    March 2024
      Android 14
     65.2.A.2.137
    • Security patch level updated. (March 1st, 2024)
    How to check the software version and how to update your Xperia smartphone
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available, Refresh Icon appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you use a device with multiple users, ensure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
    Why hasn't my Xperia phone received an update yet?
    • Software updates are released at different times depending on the operator, market, region, or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific models.
    Previous releases
    Date
    Android Version
    Software version
    February 2024Android 1465.2.A.2.113
    • GMS package updated to Nov 2023
    • Security patch level updated. (February 1st, 2024)
    December 2023Introducing Xperia with Android 1465.2.A.2.101
    • Android 14 OS upgrade.
    • Security patch level updated. (December 1st, 2023)
    October 2023Android 1365.1.A.5.113
    • Fixed call drop issue when user turn on hearing aid.
    • Security patch level updated. (October 1st, 2023)
    Aug 2023Android 1365.1.A.5.88
    • Security patch level updated. (August 1st, 2023).
    Jun 2023Android 13 65.1.A.5.65
    • Fixed an issue where the device could get too hot in certain circumstances.
    • Security patch level updated. (June 1st, 2023)
    Apr 2023
    Android 13
    65.1.A.5.50
    • Security patch level updated. (April 1st, 2023).
    Apr 2023
    Android 13
    65.1.A.5.48
    Feb 2023
    Android 13
     65.1.A.5.25
    • Security patch level updated. (February 1st, 2023).
    Jan 2023
    Introducing Xperia with Android 13
    65.1.A.4.8
    • Android 13 OS upgrade.
    • Security patch level updated. (December 1st, 2022).
    Oct 2022
    Android 12
    65.0.A.0.1185
    • Security patch level updated. (October 1st, 2022).
    Aug 2022
    Android 12
    65.0.A.0.1154
    • Security patch level updated. (August 1st, 2022).
    Jun 2022
    Android 12
    65.0.A.0.1134
    • Security patch level updated. (June 1st, 2022).
    Jun 2022
    Introducing Xperia with Android 12
     65.0.A.0.1127
