Android 9, Android 10, Android 11, Android 12, Android 13
To Add Contacts
- Find and tap Contacts.
- Tap + button on the right bottom corner.
- Input Contact information.
- Tap Save.
How can I view my SIM contacts in my phone?
Viewing contacts stored on the SIM card is subject to the installed Android version and the customization. Please note that this feature is disabled for some markets/operators. If the option to view SIM contacts is unavailable, try importing (copy) the SIM contacts to the internal phone memory and then view the contacts from there.
To import contacts from a SIM card
- Insert the SIM card containing the contacts you want to import, then start the phone.
- Tap Fix & Manage at the bottom right.
- Select Import from SIM.
- Select contacts to import, then tap Import.
- Tap the profile icon, then tap Contact App Settings → Import.
- Find and Tap Import under Manage Contacts
- Select Import from SIM card.
- Tap the menu icon (three horizontal lines), then tap Settings → Import.
How do I delete all contacts from the Xperia device?
To Delete Contacts
- Touch and hold the contact that you want to delete.
- Check the checkboxes next to any other contacts that you want to delete.
- Tap the wastebasket icon, then tap Move To Trash.
To Delete Contacts
- Touch and hold the contact you want to delete.
- Check the check boxes next to any other contacts that you want to delete.
- Tap the wastebasket icon, then tap DELETE.
How do I send contacts using text messaging (SMS)?
To send a Contact
- Tap the contact whose details you want to send.
- Tap the menu button (three vertical dots), then select Share.
- Select an available transfer method and follow the on-screen instructions.
Alternate methods
- Long press on the contact which you want to share.
- Tap the Share icon.
To send a Contact
To send your Business Card
- Swipe from the left edge of the screen to the right and select My info.
- Tap the menu button (three vertical dots), then Share.
How to mark or unmark a contact as a favourite/speed dial contact?
To add a contact to your favourites
- Tap the contact you want to add to your favourites, and then mark the star icon.
To remove a contact from your favourites
- Tap the contact that you want to remove from your favourites, and then unmark the star icon.
To use a favourite/speed dial contact
- In Contacts, favourite contacts will appear on top of the contacts list.
- Tap a contact, then select an option.
- From your Home screen, tap the Application screen icon.
- Tap the contact you want to remove from your favourites, and then unmark the star icon.
Blocking a certain number
- Find and tap Phone.
- Find and tap the menu button (three vertical dots) → Settings → Block numbers → ADD A NUMBER.
- Enter the phone number you want to block calls and texts from, then tap BLOCK.
To unblock a certain number
- Find and tap the menu button (three vertical dots) → Settings → Block numbers.
- Tap the X beside the number you want to unblock, then tap UNBLOCK.
To block incoming or outgoing calls
- Find and tap Phone → Settings → Calls → Call Barring.
- Select an option.
- Enter the password and tap TURN ON.
Alternative steps
- Find and tap Phone → Settings → Calling accounts.
- Tap name of network operators → Call Barring.
- Select an option.
- Tap the X beside the number that you want to unblock, then tap UNBLOCK.
- Select an option.
To enable or disable fixed dialling
- Find and tap Phone, then tap Settings → Calls → Fixed Dialling Numbers.
- Select a SIM card.
- Tap Activate fixed dialling or Deactivate fixed dialling.
- Enter your PIN2 and tap OK.
To send calls to voicemail
- Tap the contact you want to forward to voicemail, then tap the menu icon (three vertical dots).
- Tap Route to voicemail.
How do I search for contacts in the Phone app?
To search for a contact in the phone app
- From your home screen, tap the Phone app icon
- Tap the Search contacts field
- Start typing a name or phone number. Search matches appear in a list.
- Tap a contact in the list to place a call.
How do I add a photo to a contact?
To use a photo as a contact picture
- When viewing a photo, tap the screen to display the toolbars.
- Tap the menu button (three vertical dots) → Use as → Contact photo.
- If asked, select Contacts → Just once.
- Select a contact. If needed, crop the picture, then tap SAVE.
Alternative method
- Find and Tap Contacts
- Select the contact to which you would like to add a picture.
- Tap Edit contact at the bottom right corner.
- Click Add photo icon
- Follow the onscreen instructions.
How do I create, add or delete a group of contacts?
To create a label
- In Contacts, tap the menu (three horizontal lines).
- Tap Create label, then type a name for the label → tap OK.
To add contacts to a label
- Tap the Label that you want to add contacts.
- If there are no previous contacts in the group, tap ADD CONTACTS, then tap the contact you want to add.
- If there are already one or more contacts in the group, tap the add contact icon, then tap the contact you want to add.
- To add several contacts, long press one contact until a check box appears beside every contact. Tap the check box for every contact you want to add, then tap ADD.
To rename a label
- Tap the label that you want to rename.
- Tap the menu (three vertical dots), then tap Rename label.
- Type the new name, then tap OK.
To remove contacts from a label
- Tap the Label that you want to remove contacts from.
- Long-press one contact until a check box appears beside every contact. Tap the check box for every contact you want to remove.
- Tap the menu (three vertical dots), then tap Remove from label.
To remove multiple contacts from a label
- Tap the label that you want to remove contacts from.
- Tap the menu (three vertical dots), then tap Remove contacts
- Press the cross icon on the right of the contact.
To Delete a Label
- Tap the label that you want to delete.
- Tap the menu (three vertical dots), then tap Delete label.
How do I find and edit my personal contact information in the Contacts application?
To edit personal contact information
- Tap menu icon (menu icon) → Settings → Your info.
- Input or Edit the desired information.
- When done, tap SAVE.
- Tap (menu icon) → My info.
- Tap the edit icon (pencil) in the upper right corner.
- Edit the desired information.
Caller ID and Spam feature: How does automatic name/spam detection work?
If you get an incoming call from a phone number that's not in your Contacts list, your phone does an online search on Google Maps to try and find the name of the caller. This is why your phone might sometimes show you the caller's name even though you've never added it to your Contacts.
You can switch this automatic name search feature on or off by going to Calls → Settings → Caller ID / Spam.
You can also decide if you want Spam calls to be automatically detected or not.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
