Solution
To use Wi-Fi tethering in the 5 GHz band:
Android 12 or higher
- Find and tap Setting → Network and Internet → Hotspot and tethering → Portable hotspot / Wi-Fi hotspot.
- Tap the slider beside Use 2.4 GHz only turn OFF (gray).
Android 11
- Find and tap Setting → Network and Internet → Hotspot and tethering → Portable hotspot.
- Tap AP band and select 5 GHz band preferred.
- Tap the slider on the top and turn it ON (blue)
Note for Xperia 10 III and 10 IV: Immediately after starting Wi-Fi tethering, you cannot connect from the client device for up to 3 minutes for checking the presence of radar in the 5 GHz band, so please connect after the notification of "5 GHz portable hotspot is available" is displayed.
Also, if radar is detected in the 5 GHz band during Wi-Fi tethering, the communication between the client devices will be disconnected, but after a while, the client devices will automatically reconnect.
Note for Xperia 10 III, 10 IV, 1 III, 5 III, PRO-I: The Wi-Fi tethering operates in the 5 GHz band if there is a frequency that can be used in the 5 GHz band, and operates in the 2.4 GHz band if the frequency in the 5 GHz band cannot be used.
Note for Xperia 1 IV, 5 IV, 5 V, 1 V, 1 VI, 10 VI, 1 VII, 10 VII, and 1 VIII: The Wi-Fi tethering operates in both 2.4 GHz and 5 GHz band if there is a frequency that can be used in the 5 GHz band, and Wi-Fi tethering operates in the 2.4 GHz band if the frequency in the 5 GHz band cannot be used.
Note: 5 GHz Tethering support may vary by country/region.
