Article ID : 00266561 / Last Modified : 20/05/2026Print
How do I transfer data to the SD card?
    You can transfer data from the internal storage to a memory card or using a Files application. Depending on your Xperia device, the Files application may be pre-installed on your device. But, you can always download a third-party* file manager app from Google Play.
    To Transfer the data (Media file / Documents) using files application.
    1. Find and tap the Files app new files icon. It's sometimes placed in the Other folder on the Applications screen.
    2. Tap ”Internal storage" to browse the internal storage, "SD Card" (if available) to browse an external memory card.
    3. Touch and hold a file to highlight it. You can then share share button  the file, or tap more option button and then move or copy the file to another location.
