Article ID : 00237324 / Last Modified : 20/01/2026Print
    My Xperia smartphone has no network coverage or mobile data connection
    If your Xperia smartphone can't connect to a network or mobile data, it may be due to incorrect network settings, SIM card issues, or temporary network outages. In this guide, we'll show you how to fix common network issues, including how to turn off Airplane mode, search for available networks, disable STAMINA mode, and reset your phone.
    Before you start
    • Confirm that your phone has the latest software version:
      • Don't know which Android version you have? Find and tap Settings → About phone → Android version.
        Note: If you don't see the About phone option under Settings, tap System
        → Check the Android version under Software update.
    • Keep these tips in mind to improve connectivity:
      • Keep your phone updated
      • Avoid areas with poor signal coverage
      • Use the Wi-Fi Calling feature in low-signal areas (if available)
    Step 1: Basic Checks
    Step 2: Adjust Your Network Settings
    Notes:
    There are additional settings you can adjust to improve your mobile data connection.
    Step 3: Check Your SIM Card
    Step 4: Adjust Your Battery and Power Settings
    Step 5: Update or Reset Your Phone
    IMPORTANT:
    A factory data reset will erase all data on your phone. Back up any important data that is saved on the internal memory of your phone to an external memory card. If you have any encrypted files stored on an SD card, you should also remove the encryption to ensure you can still access them after the reset.
    Notes:
    • If you're using the Settings menu to back up your data, keep in mind your app data, phone settings, and call history will be backed up automatically.
    • Your phone will not revert to an earlier software version when you perform a factory data reset.
    • To avoid permanent phone damage, do not interrupt a factory data reset procedure.
    Step 6: Contact Us
    If the issue persists, contact customer support to arrange a repair.
