An app has disappeared from the Application screen, how to find it? (Android 9 or higher)
What are the reasons an app has disappeared from the application screen?
Try the following methods one after the other. Verify whether the problem is solved after each method, before trying the next one.
Check if you can find the missing apps or if the apps are installed on your device
Enable the app in the Settings
If your Android version is Android 9 and above, up to 11, try the following methods.
