Article ID : 00247357 / Last Modified : 20/01/2026Print
What shooting modes are there in Photography Pro?
    The different modes in Photography Pro are:
    • Auto mode: allows you to shoot still images of any subject under any condition with good results by setting the values determined by the product.
    • P mode (Program Auto): you can shoot with the exposure (and the shutter speed) adjusted automatically. Also, you can select various settings using the menu.
    • S mode (Shutter Priority): allows you to shoot fast-moving subjects etc., by manually adjusting the shutter speed.
    • M mode (Manual Exposure): allows you to shoot still images with the desired exposure by adjusting the exposure (and the shutter speed).
    • MR mode (Memory Recall): allows you to register frequently used combinations of modes and setting values (only available in Xperia 5 II).
    • Basic mode: allows you to quickly access a range of easy-to-use photography features, including a touch shutter button, Portrait orientation, Bokeh effect, Panorama, and more.
      Note: The Basic mode is only available in the Xperia 1 III and later models, where the Camera app function has been merged to Photography Pro basic mode.
