Notice regarding incorrect display of screen resolution settings menu for Xperia 1 V
We sincerely appreciate your continued support and use of Xperia products.
It has come to our attention that after upgrading to Android 15, the screen resolution settings menu is incorrectly displayed within the settings menu of the Xperia 1 V smartphone.
In response, we will implement a software update to remove the screen resolution settings menu and revert any changes to the screen resolution settings. We’d like to ask customers who own an Xperia 1 V to update to the latest software. The release timing of the software may vary depending on your carrier.
Your Xperia 1 V is equipped with a 4K display, and 4K content displays automatically in 4K regardless of the screen resolution settings in the menu. Therefore, you can continue enjoying 4K content even after the software update mentioned above!
We apologize for any inconvenience caused.
