Article ID : 00356604 / Last Modified : 20/01/2026Print
    Accessibility for Xperia smartphones - Android 11 to 14
    Xperia smartphones support the following accessibility features.
    You can access them from [Settings] → [Accessibility] (some features may be excluded).
    • These features are available on Xperia smartphones with Android 11 or later installed. Some features are available from later versions, so please see the individual feature columns.
      • To check which Android version your device has, find and tap [Settings] → [About phone] → [Android version].
    • Some features might require app installation from Google Play, depending on the product and/or Android OS version.
    What accessibility features help with vision and visibility?
    TalkBack
    Use your device without looking at the screen by receiving spoken feedback.
    Select to Speak
    Tap specific items on your screen to hear them read aloud.
    Text-to-speech output
    Set the speech rate, pitch and language for text-to-speech output.
    Font size
    Make the text on the screen smaller or larger.
    Display size
    Make items on your screen smaller or larger.
    Bold text
    Use bold font to improve visibility.
    Note: Available on Android 12 or later.
    Colour correction
    Adjust how colours are displayed on your device.
    Colour inversion
    Change your display to use a dark background.
    Remove animations
    Reduce animations that appear while using your device.
    Large mouse cursor/
    Large mouse pointer
    Make the mouse pointer larger.
    High-contrast text
    Make the text easier to read on your device.
    Extra dim
    Dim your screen beyond your phone's minimum brightness for more comfortable reading.
    Dark theme
    Change your display to a dark background.
    Magnification
    Zoom in or magnify to better see your device's screen.
    Audio Description
    Hear a description of what's happening on screen in supported movies and shows.
    Note: Available on Android 13 or later.
    What accessibility features help with hearing?
    Live Transcribe
    Show speech as text on your screen to participate in conversations around you.
    Sound Notifications
    Your phone will always be checking for sounds you want to be notified about.
    Mono audio
    Integrate audio channels during playback. Combine stereo channels into one for single-ear listening.
    Audio balance
    Adjust the left and right audio balance.
    Caption preferences
    Set the caption size, style and language.
    Flash notifications
    Flash the camera light or the screen when you receive notifications or when the alarm sounds.
    Note: Available on Android 14 or later.
    Hearing devices
    Set up and manage ASHA, cochlear implants, and other amplification devices.
    Note: Support varies depending on the product.
    Hearing aid compatibility (HAC)
    The device supports magnetic coupling for a hearing aid device. If using a hearing aid with T-coil, turn on "Hearing aid compatibility" in Hearing devices, or you can also find it in the [Phone] app under [Settings] → [Accessibility].
    Teletypewriter (TTY)
    You can use the Text Telephone (TTY) mode if connecting a teletypewriter via a 3.5mm audio jack.
    Real-time text (RTT)
    You can use Real-time text (RTT) to send text messages or generate captions over the phone.
    What accessibility features help to interact with your smartphone?
    Accessibility Menu
    Control your device from a large on-screen menu.
    Switch Access
    Interact with your device using one or more switches.
    Touch and hold delay/
    Touch & hold delay
    Adjust how long you need to touch the screen before it's registered as a 'touch & hold'.
    Time to take action (Accessibility timeout)
    Set how long temporary messages that ask you to take action stay on screen before disappearing.
    Click after mouse pointer stops moving
    Set the mouse cursor to take action automatically when the cursor stops moving for a set time.
    Navigation mode/
    System navigation
    Choose between 3-button navigation and Gesture navigation.
    One-hand mode
    One-handed mode makes it easier to reach distant parts of the screen with your finger.
    Power button ends call
    Press your device's power button to end a call.
    Auto-rotate screen
    Automatically rotate your screen when you change your device's orientation (portrait or landscape).
    Vibration and haptics/
    Vibration & haptics
    Enable vibration for ringing, notifications, and touch feedback.
    Smart call handling
    Handle incoming calls without having to touch the screen.
    Swipe to invoke the assistant
    Swipe up from the bottom corner to invoke the digital assistant app.
