Welcome to the Xperia 5 V software release page.
- Each Xperia smartphone receives security and software updates throughout its lifecycle.
- Software release timings may vary by operator, market, region, or country.
Latest Software Release
Date |
Android version |
Software version |
Software improvement |
April 2024 |
67.1.A.2.229 |
How to check the software version and how to update your Xperia smartphone
Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
When a software update is available, appears in the status bar.
To download and install a system update from the Notification panel
- If you use a device with multiple users, ensure you are logged in as the owner.
- Drag the status bar downwards to open the Notification panel.
- Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
- When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
Why hasn't my Xperia phone received an update yet?
Software updates are released at different times depending on the operator, market, region, or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific models.
Previous release
Date |
Android version |
Software version |
| March 2024 | Android 14 | 67.1.A.2.220 |
| February 2024 | Android 14 | 67.1.A.2.208 |
| December 2023 | Introducing Xperia with Android 14 | 67.1.A.2.182 |
| November 2023 | Android 13 | 67.0.A.6.99 |
| October 2023 | Android 13 | 67.0.A.6.75 |
September 2023 |
67.0.A.6.60 |
