NTSC
*Some functions are not available, depending on the model.
NOTES:
- Movies are recorded in HD format and MP4 format simultaneously when Dual Video REC is set to On. You cannot record only MP4 movies with this camera.
- Dual Video REC will be set to Off when Frame Rate is set to 60p.
When recording MP4 movies, set Frame Rate as follows according to the file format setting.- AVCHD file format: set to 60i or 24p
- XAVC S HD file format: set to 30p or 24p
- XAVC S 4K file format: set to 30p or 24p
Available file formats differ depending on the model of the camera.
- If your camera has the Intelligent Active setting in the SteadyShot menu, set SteadyShot to a setting other than Intelligent Active. Dual Video REC is not available when Intelligent Active is selected.
(Depending on the model, the SteadyShot settings are different.)
Playing back MP4 movies:
Switch the format of the movie to be played back by selecting the 4K, HD, 4K/MP4 or HD/MP4 icon displayed in the upper right of the playback screen.
PAL
NOTES:
- Dual Video REC will be set to Off when Frame Rate is set to 50p.
When recording MP4 movies, set Frame Rate as follows according to the file format setting.- AVCHD file format: set to 50i or 25p
- XAVC S HD file format: set to 25p
- XAVC S 4K file format: set to 25p
